Stainless Steel Braided Brake Lines On ABS
Old 12-23-2011 | 02:41 PM
Terrabella's Avatar
Terrabella
Default Stainless Steel Braided Brake Lines On ABS
Anyone install stainless steel braided brake lines on a 09 or above Ultra Classic with ABS brakes? And, if so, what kind of cost is one looking at.
Old 12-23-2011 | 04:09 PM
steelhead's Avatar
steelhead
I just did it last week for the front only on my SG. Was about $60 for the the ABS module to master cyl. section only. I was changing out bars and needed longer brake and hydraulic clutch lines. I did not change out the lower lines.
I was needing to match just braided stainless but if I was going to do the whole shebang, I would co with Magnum Sterling Chromites. I used them on my RKC and was into the front brake all parts, clutch and throttle/idle cables for about $330. I went through Dr. V-Twin here and saved significant coin plus got them in a week.
Old 12-28-2011 | 10:28 AM
kingan936's Avatar
kingan936
Magnum is great
Old 12-28-2011 | 10:32 AM
kingan936's Avatar
kingan936
I went with magnum, for everything your lookin at around 300, theyre quality is top notch. The bottom lines are what get you. If you think a bar change is in the future now would be the time, so u dont end up buying 2 cables
Old 12-28-2011 | 11:48 AM
mkguitar's Avatar
mkguitar
make sure your cables are DOT/TUV approved.
there have been lines on the market which are not and are "show use only"--- and the inner lining can break down when exposed to some brake fluids and/or sun.
Mike
BooDaQ
04-21-2018 08:44 AM
LA_Dog
03-25-2015 01:39 AM
TUCCI
05-08-2012 01:10 PM
kwb
11-01-2010 10:22 PM
kwb
02-28-2009 07:45 AM
Quick Reply: Stainless Steel Braided Brake Lines On ABS
