Road Glide Fairing Easy Removal and Install
MY Top Mechanic at North Texas Harley showed me the easy way to remove and install the Road Glide Fairing the easy and Fast Way , First is remove Fairing , lift up straight , and wiggle a little , then remove the headlight assembly, by squeze in the Adjusters blocks with a long pick , and remove headlight assembly , then you see where the fairing goes on the dreaded hooks , line up fairing , assemble with all screws , then lay headlight assemble on front fender ( use a towel on fender first ) , then plug up bulbs wires to wires in fairing ( I use DDM Tuning 's , HID bulbs and slim ballast $ 70.00 , lifetime warranty ) , line up adjusters blocks and push in , and make sure they lock in done , Gary Saia
On top of the radio chassis. They can be difficult to hook onto because you can't see them. This is why we remove the headlight assembly so you can see what you're doing. The hooks are supposed to carry the weight of the fairing but if you do a search you'll see many posts complaining about the chassis digging into the fairing. I beleive HD finally changed the chassis to allow more clearance in 2012.
