Performance Exhaust and Tuning
Depends a lot on your setup. Some will tell you they have a map for you or will make one and they might, but don't count on it. You can use the auto tune features and do fairly well, or get a dyno.
If all you are going to do are slipons and an air cleaner save yourself a lot of hassle and a lot of money and check out the Xied's from Nightrider. Give Steve a call.
http://www.nightrider.com/parts/
A lot of people will say you need a tuner or this or that. There is no truth in that... the Xieds work great for around $125. Give Steve a call.
Since the XIED zombies have already started to appear, I'll jump in and say that you'd be wasting your money on them, as they do nothing to address the VE or timing tables, which is what's affected when intake and exhaust are changed.
You don't need to worry about all that crap. The Xied's will make your bike run great. For the needs you described above and If you are not **** retentive, then the Xied's are all you need.
05Train obviously needs a tuner, he is into tweaking all that stuff, but that does not mean you do. If you want to keep it simple the Xied's are all you need. If you want to be able to change everything that is controlled by the ECM then you need a tuner. So the choices are, do you want to dig into and have control over everything or do you want plug and play.
See, I told you so.
The choice is yours.
The second that Steve from Nightrider or any of his zombies can explain how his overpriced resistors compensate for the additional airflow of a Stage One, will be the day that unicorns dance in fields of money trees.
OP either get a dynojet product from someone like Fuel Moto with your setup, or if you have any plans of going further than a stage 1 at any point later on get the TTS.
Not so much. You can **** your money away on something that might make you feel better but does nothing for your bike, or you can do it right.
Call Jamie at Fuel Moto or at least go to his site and read the info on tuners etc. Then call him tell him your goals and he will recommend a solution, probably a PC V or PV depending on a few things like cost, piggy back unit , ability to monitor etc.
Ive used SERT, Fuel pak, PCIII, PCV and now the PV unit and for me the PV is the easiest to use . Jamies MAP was super close and the bike runs great. Im bored and want to play with it so Im starting some data logging to see if I can self tune for a little more now. Plus any additional changes I do in the future the PV will be able to handle.
How much money do you have to spend?
How much effort are you willing to put into making your bike run properly?
How much control do you want to have over the ECM?
Regardless of what the experts say, the Xieds mentioned above are a good viable option. In no way can they do what a tuner can do, but they will make your bike run much better, they are much cheaper than a tuner and much easier to use. Do not disregard them just because they do not give you complete control over the universe.
