Should I detach?
Should I detach?
Looking for some advice on how to best spend hard earned dollars. I bought 2012 UC Limited in Big Blue Pearl/Black. Awesome. Worked a deal to have the tour pak made detachable when I was negotiating price. I'm beginning to wonder how often I might really pull the pak and wonder if guys out there that did this find it was worth it? I really want to upgrade the rear shocks to the HD premium clickers and might be able to work a deal to use those dollars for that purpose ( some or all). Thoughts from those who have the detachable kit? Thanks for the help.
I take mine off all the time. I just like the way the bike looks and feels without it.
I put it on when I need it so I'd say its 50/50........My advice is do it now while you can its way easier then latter........
As for the shocks. Belive it or not its easier to change those then set up the tour pack and you can get way way better shocks after market then Harley's...I have Progressive 440's (my last two bikes).
If you ride solo very often you may enjoy being able to have it off. My friend (riding a Limited) and I swapped bikes on a ride. He commented that mine felt noticeably lighter w/o the trunk and its weight up high and so far rearward. (That weight was the first thing I noticed on his) And for most solo riding the saddle bags should be adequate.
I have 2 ultra bikes. One bike is the 2007 and the other bike is FHLTK 2011. Both have the quick detach. I like riding without the sofa chair (Tour PAK). I only use it when my wife wants to ride with me. Without the sofa chair or the tourpak, it looks like a street glide. I changed the rear tail light to a street glide bullet turn signal and put a Rear Fender Fascia skirt filler panel 59739-09. If you want a pic of the rear, I can post it. Let me know what you think? Look at my Avatar. Thats my other Ultra Classic 2007. The bottom one is the ultra classic limited 2011.
the detachable kit is cool and best if you think you will be taking it on/off alot.
if you think you will have it off much of the year, then put it on for a long trip.
it does not take more than 30 minutes to loosen the bolts and unplug wires to disconnect it.
however if you are shy about wiring, let the dealer do all the hard work.
if you are talking about the -1" street glide rear shocks, they are worth about $230 from an online disc. dealer.
so get your best bang for their buck
mike
mike
