Well bit the bullet this year and decided to go with extended bags. I went with Sinister Industries 4" extended bags. They are a great bag. I also went with Milwaukee Bagger rear fascia. Had to do some trimmimg on this to get it where I liked it. So off to the painter and will post when completed. Now the question will be do I go back to the stock fender.... I'm thinking it may, since the bags are now extended....
Went with Sinister fender and CycleSound lids. The quality is good. Cutting, drilling shimming takes a little time to get everything lined up.nothing square on the fender, matching the center line to cut the fender lights was a little bit of a pain.close enough to let the painter finish up the prep work.
CycleDrider, I am thinking of going with that same setup. If you had to do it over would you still go with what you got? How much "adjusting" did you have to do to get things to fit right? I am anxious to see the final product.
Got everything back together last night, cutting in the lights, drilling all the holes, trimming the exhaust cut outs, lots of patience but nice feeling when it's done. Now I have to select paint scheme,
