Rockford Fosgate 300X4 Did it BLOW today! Need Advise
both amps fried.. i must say i am quite impressed with the amp in high level setting! i jumped to conclusion about the amp sucking.i should have been more educated on the pass setting on an amp. thats my fault.. none the less im back rockin. hopefully it stays that way!! amp has to be on high level setting if youre running more than 2 speakers! the little white brp light barely comes on now too. it just pulses slightly..on all pass it was light bright all the time..
Location: 12 year, Colombia, 4 years Mexico, currently In Kuwait, but Boston is HOME!!
Really pissed with Bagger Nation! I asked them if they had the amps for my bike June 2012 june 10th, they said yes, charged me for them, sent me one that was a two channel amp, I called them back and there response was " we dont or not always here because we are put on the rally train" I said well then why did you tell me you had the amp when you kniew you did not??????? I need 4 channel , not a two. THey said you will have to wait till we come back. WTF is that!!!!!!!!!!!!!!!!! Really?????? Paul Yaffe can go **** himslef!!!
Well after all the hassle. I found out that my ground was insufficent. I listened to some bird brain who mentioned grounding the amp to the forks, to the lower triple tree..Bad idea!!! it should be grounded to you battery!! And on high pass the amp actually still delivers all the bass you could expect out of 4 coax speakers on a bike. On all pass it would distort easily. The high pass keeps you from ruining your speakers!
I never did change the factory settings either. I'm not sure about the pass setting. I kept the gain at about 50% also. Any pointers anyone? I'm not having very good luck.
Well....my first one, I went to the tree for the ground. (Before finding this thread) My second went to the battery for the ground. Both of those have burned up. I'll hook the third one up and see how long it lasts.
Use 10 AWG power and ground, both to the battery. Frequency set to just under 100hz, gain at 4 and HP set with, high level speaker inputs. (cut those F#cking RCA's OFF!!) Absolutely no complaints, its loud and clear at 80m/hr and I have checked and triple checked for excessive heat from this amp and I have not experienced any. If anything I will take my fairing off in the next few weeks and back the gain off to 3 as i get a little distortion at around 3/4 volume.
Base response is more than adequate (remember its a Harley, not a Home Theater..) I did use the J&M inner fairing acoustic dampening pads - this tightens up the base "some what" (... note above point about Harley, not Home Theater..)
Also worth noting is that the quality of the media file your playing makes a hell of a difference...
