SE 103 Stage II kit
#41
makes me wonder about the tune my HD dealer did with my bike this Spring. They had it for the whole day, and mentioned doing a data collection and V-tune.
Hmmm- SE super tuner pro is what I have, the bike runs great. I did not get any dyno sheet though..... at the end of the day when I picked it up.
I will say it ran better than before.
#43
A friend of mine had the SE 103 installed last year. When he let me ride it I couldn't believe I was driving a Harley. Bang for the buck, best money a guy could spend on upgrades. It's too bad the 103 that comes on the harley's is NOTHING like the SE 103 you are having installed. Our bikes are so underpowered compared to other manufactures bikes. BUT with your upgrade you will be smiles from ear to ear!
Enjoy,
T
Enjoy,
T
#44
Smarttune
V-Tune it whats used on the TTS Mastertune systems. the Super Tuner has a built in program called Smarttune, It's pretty much the same thing as V-tune. In a nutshell they can be set up to record data, then the user rides the bike around and the bike records info, then when done you can download the recording and make corrections to your MAP. After a few good sessions the bike should run half way decent. It's in no means a dyno tune but it is effective. I would have to guess that your dealer either doesn't have a dyno or they don't have anybody that can run it.
Also in your opinion, how well do the up-the-tailpipe AFR sniffers work as opposed to ones that are screwed in a bung just off the head like on the pre 2010 models. Thanks!
#45
#46
Mikebaby,
I see that you have SuperTrapp Slip-Ons....tell me what you think of them. I have a very similar set up but have not changed out the pipes. I would like a lower tone/growl but do not want additional bothersome noise. Have you done anything with the header pipes or the cat converter?
mikebaby
#47
There is something about the Smarttune feature I'm curious about. If the stock narrow band O2 sensors can only read from 14.2 to 14.7, how can you tune to a lower AFR? I hope someday the MOCO quits jerking us around with this junk EPA driven system and gives us true wide band adjust-ability but I know I'm dreaming. (Sorry, jumped up on my soap box again!)
The up the pipe sniffers work just fine, actually very accurate as long as you keep the filters in the sniffer clean. Some o2 sensors can be a real PITA to get to when the pipe is on the bike so the probe is the way to go.
