Harbor Freight Sale
The coupon code works online too, I downloaded the picture to read the code and entered it in and it worked - this is the code
18412628
lets see if it goes through they did not charge much for regular ground shippingto where I live, less than 10 dolars.
Thanks to the OP.
1500 Lb. Capacity ATV/Motorcycle Lift
1 1 (x) $99.99
Discount: -$40.00
$59.99
Subtotal $59.99 Shipping $6.99 Tax $3.96Grand Total $70.94
18412628
Thanks to the OP.
Item: 2792
used coupon code: 18412628 (-$40.00) 1 1 (x) $99.99
Discount: -$40.00
$59.99
I bought the yellow jack, and returned once I opened the box. I bet this guy wishes he did the same...
http://roadglide.org/showthread.php?...ghlight=harbor
Table lift = yes...jack = no
It's definitely economical, but you get what you pay for w/this jack & after going to local HF store, elevating & standing on it...very unstable. I'd say it's good for lightweight bikes (i.e. dirt, small street) - not beefy enough for HD, or anything over 500lbs...JMO.
One day I slowly let the bike down. As the tires touched the floor it began to lean towards the kickstand. Suddenly I realized it had gone too far. I had left the kickstand up. There it was, resting on the engine guard. :-(
I would suggest that one always leave the kickstand down when on the jack. That way, if the jack seals fail, it will come down and rest in the parked position.
I got my jack used, off Craigslist. Though it is not a HF jack I did take the time to adjust the bars that go into the recesses. The ones that lock the jack into place at a specific height. Sometimes one would catch and the other would not. Now they catch as they should.
well if you follow the instrucktions and ALLWAYS set the lock . you will never have a problem . if your leaving it up let the presure off the hydrolics after you set the lock .
the jack is safe just not STUPID Proof.
Matt i did the same thing with the kick stand , but caught it just in time DOH ! Da !
