Oil Cooler
Old 12-13-2011, 01:43 PM
Aces&Eights's Avatar
Aces&Eights
Aces&Eights is offline
Default Oil Cooler
Does anyone have any insight on what oil coolers not to use. I have the stock HD oil cooler and I am seeing temps of 230 to 240 with a real fat tune in the bike, I want to get it tuned again but I know that I need a new oil cooler. I like the looks of the Pro 1 oil cooler but I don't know how well they work.
Any info would help.
Old 12-13-2011, 02:16 PM
hoethree's Avatar
hoethree
hoethree is offline
Wicked, sick bike! send me the used HD oil cooler when ur done with the change out
Old 12-13-2011, 02:20 PM
Clayvis's Avatar
Clayvis
Clayvis is offline
Check out Jagg oil coolers. I like them the best. They have one now with a built in fan. There are others, but Jagg has been around a long time. Call them and talk to Marvin. Awesome Glide!
Old 12-13-2011, 02:30 PM
tj316's Avatar
tj316
tj316 is offline
I removed my HD oil cooler and installed the Jagg Fan Assisted oil cooler and my temperature dropped on an average of 25* , I am very happy
Old 12-13-2011, 03:21 PM
Punjabi Rider's Avatar
Punjabi Rider
Punjabi Rider is offline
I keep staring at your bike took me while to read what you were saying any way I use HD premium on mine last 63K miles and performs OK I think.
Old 12-13-2011, 03:41 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
consider that you do want oil temps above 212º to evaporate any water out of the oil- I have the H-D and it works fairly well.
You may get slightly better cooling with out a chrome cover blocking part of the air flow, if you have that on .
If I were shopping again I would consider the jagg.
there is also the cooler that mounts to the underside of the oil pan-- can't remember the name just now
saw it at sturgis and it is nifty ( as long as a rock doesn't hit it) but pricey, like $600
some guys plumb the crashbar and run oil through that
the oil pan changed going into 09 and the oil now flows through a baffle system to have the return oil directed further from the pick up
mike
Old 12-13-2011, 03:48 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
mike
Ummm no, water evaporates at a much lower temp than 212 degrees, it boils at 212.
Old 12-13-2011, 03:50 PM
drukanfu's Avatar
drukanfu
drukanfu is offline
I've had several and they all seems to work ok back in the wagon train days, I have no experience with the Pro 1. I 've got the Ultra Cool with the fan assist and am very pleased. http://www.ultracoolfl.com/
Old 12-13-2011, 04:05 PM
Moneywoes's Avatar
Moneywoes
Moneywoes is offline
I'm running this one. don't know how much difference it made temp wise, I do know it was noticeable.
http://harleyoilcoolers.com/index.html
Old 12-13-2011, 04:06 PM
Moneywoes's Avatar
Moneywoes
Oil Bud
mike
Quick Reply: Oil Cooler
