Paul Yaffe's BaggerNation Rockford Fosgate System Installed!
Old 12-20-2011 | 03:19 AM
ripper43's Avatar
ripper43
Originally Posted by pauly3
Ripper43,
Post some pics and you may convince me!
Which biketronics kit did you get?
How much was it?
Did you lose access to your hand controls?
when it's all done I might post a picture.
I've had this kit on 3 different bikes and been happy every time. it's part #
BT1005
$219.00 shipped
No that is one the purposes of the kit. it allows you to mount an aftermarket radio with nice clean results and also retain your handle bar functions.
  #52
Old 12-20-2011 | 03:32 AM
ripper43's Avatar
ripper43
Originally Posted by jahays32
Hawgwired kit is top quality and no gap. $240 to $260. Sony only decks or any brand deck.
Put this kit in my brothers bike. Face plate stays on the mount, you dont even need to pull any of the kit out to change decks. Just bend the tabs back down on the decks cage and take out the screw in the back of the radio. Took me 20 mins to swap in a new deck for him.
Trim ring is high quality aluminum not cheap plastic. All controls are jut like stock except you don't have AVC, no big deal.
Damn, that is a real nice set up... for $40.00 more I may go with this next time.
http://hawg-wired.com/product_info.p...products_id=96
  #53
Old 12-20-2011 | 10:24 AM
LADNAR's Avatar
LADNAR
Originally Posted by piesik650
email Brady he has done alot for me, he will help you out. Baggernation is usually hard to get a discount out of but give Brady try. bpitmon@paulyaffeoriginals.com
Well, I never did hear back from the customer service email that I sent asking for a discount from yaffe.
This morning I emailed Brady, so we'll see if this one gets me anywhere.
I also got a PM this week, for a retailer that can offer 10%.
That one will be my plan C.
I'll give an update, once/if I hear back from Brady. Being this close to Christmas, I'm not anticipating a fast response.
I know, I'm not doing much at work this week...
  #54
Old 12-20-2011 | 05:37 PM
GLACIERPEARL's Avatar
GLACIERPEARL
If you don't need AVC, it is a nice install kit.
  #55
Old 12-20-2011 | 06:22 PM
djack's Avatar
djack
great job, looks good, can you hear your system at highway speeds with a full face helmet?
  #56
Old 12-20-2011 | 06:31 PM
cardboard's Avatar
cardboard
Hey you got my lift table
http://www.completehydraulic.com/lif...ycle-tcml.html
  #57
Old 12-20-2011 | 10:26 PM
pauly3's Avatar
pauly3
djack,
Thanks for the compliment! I apologize I cannot answer that as I ride with a half helmet. I have heard that audio though a full face is like listening to your home theater while outside your house during a windstorm! J/K
  #58
Old 01-05-2012 | 12:34 PM
04Glider2's Avatar
04Glider2
1st Gear
Default RF and Polk Audio Install
Ok Finally did it,
Gave up on the J+M 5 1/4's with tweeters in grilles, not enough bass.
So here we go, added:
Polk Audio DXI 6500 in stock location with Arc Audio rings, put the tweeters in below the guages like the Yaffe set up does.
Polk Audio DXI 690's in the fairing facing the forks ( 6X9")
Rockford Fosgate PBR300X4 set to run the 2 channel in puts to 4 channel out
Mounted everything inside the fairing so the saddlebags and tour pak are still free to use.
I am using the J+M grilles so when I paint the inner fairing I can paint the grilles to match.
I have put together a complete install photo album here on Photobucket for you to have a look at .
Sound is fantastic and hopefully amp heat in the summer will not be a problem.
Your feedback is welcome and I will answer any questions if I can.
Enjoy:
http://s1092.photobucket.com/albums/...reo%20Upgrade/
That being said I am using the speaker wires from the stock head unit into the RF amp, that turns it on when I turn on the radio, but when I turn off the radio the amp stays on and I get a pop when turning off the ignition. Turned the small dial on the amp from 4 to 6 volts and there is no change, any thoughts will be appreciated. Positive wire from battery to amp and ground to fairing mounting bolt (10" grd wire). Othere than that I am happy so far.http://s1092.photobucket.com/albums/...reo%20Upgrade/
  #59
Old 01-05-2012 | 12:40 PM
1320str8_liner's Avatar
1320str8_liner
I get a pop turning mine on/off, maybe someone can chime in and give a solution to the "pop"
  #60
Old 01-05-2012 | 12:51 PM
djack's Avatar
djack
djack,
I like that Pauly, listening to your home system outside, I went with the J&M 7.25 rokkers and 250 watt and was very pleased, i think it sounds great. I have`nt been able to take it out on the road yet so i will have to wait and see or should i say hear
