which layback license for detachable tourpak?
Old 12-12-2011, 01:21 AM
webbug's Avatar
webbug
webbug is offline
Red face which layback license for detachable tourpak?
I have 09 Ultra with Detachable tourpak kit. I dont want to use the license mounting kit that came with it.
Which layback license kit will work with my setup? Will I need to drill for holes or I can use the existing detachable mounting?
Attached Thumbnails which layback license for detachable tourpak?-layback.jpg
Old 12-12-2011, 01:40 AM
mkguitar's Avatar
mkguitar
mkguitar is offline
either drill holes, or switch to a road king signal bar & plate mount.
The signal bar is a little narrower and incorporates the plate light
Many of the kits/parts/mounts made for the 08 and earlier narrow fender don't fit the wide fender09+ bikes
here' my 09 FLHTC with the tourpak off
Old 12-12-2011, 05:38 AM
ACLazer's Avatar
ACLazer
ACLazer is offline
I agree, the plate bracket that comes with the Tour Pak Kit is really fugly. I installed a Kuryaykn 3165 Layed Back and Curved Plate on mine. I know it says for 08 and below, but if you get 2 new 1/4x20 SS Mounting Screws that are 1/4" longer, it bolts up real nice, with no drilling. You can also still use the HD square chrome bracket on the rear too.
http://www.ebay.com/itm/KURYAKYN-CUR...item20b96e824b
Here are a few pics
Attached Thumbnails which layback license for detachable tourpak?-egc-008.jpg   which layback license for detachable tourpak?-egc-010.jpg   which layback license for detachable tourpak?-egc-009.jpg   which layback license for detachable tourpak?-egc-011.jpg
Old 12-12-2011, 06:02 AM
fxlowboy's Avatar
fxlowboy
fxlowboy is offline
take a look at Haulenass website i bought mine there... and he is a site sponser
http://www.haulenass.com/category/309872
Old 12-12-2011, 11:20 AM
Mark98012's Avatar
Mark98012
Mark98012 is offline
I bought the plate bracket for a streetglide, drilled and tapped a couple of 1/4 x 20 holes in the turn signal bar bolted it on. No direct light on the plate but there's enough light back there (runn/brake/turn light module) anyway.
Mark
Old 12-12-2011, 12:08 PM
ACLazer's Avatar
ACLazer
ACLazer is offline
I just couldn't bring myself to drill and tap anything on my new ride
Old 12-12-2011, 12:39 PM
88 Paladin's Avatar
88 Paladin
88 Paladin is offline
JP cycles
Old 12-12-2011, 12:48 PM
b17467's Avatar
b17467
b17467 is offline
I think this is what I want to do with my Limited. Does the bar hold the plate mount also ? and is the 09 the same size as an 11 ?
Old 12-12-2011, 02:45 PM
acchd's Avatar
acchd
acchd is offline
Softbrake & JP Cycles make a license plate bracket they'll go directly under your stock turn signal bar and bolts to it. You'll need a new tail light lens with clear lens bottom if go that route. I got a new tail light with clear bottom for sale over in Touring classifieds. I ended up buying and installing a Street Glide turn signal bar with lighted license plate bracket.
Here's pic of my present setup.
Old 12-12-2011, 03:01 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
Yes, the plate mount is integral to the signal bar as is the license plate light. Most of the 09+ rear stuff is interchangable
I bought mine for about $75 as a take off ( with lens).
It is a stock 2010+ road king.( if you go to the dealer you can eyeball them.)
the plate mount has a rubber bumper on the backside which rests on the chrome at the top of the fender tip.
signal bar is narrower, turn signals plug right in, you may need to splice in the plate light depending on what you have going on for rear lighting- ( I have a bunch of stuff going on back there so had to adapt the wiring to my needs- bottom photo you can see I added LEDS for brake function to my tip light- yes, i know they sell them, but I have LEDS in the garage and I added blue as well as red for the "blue dot" look)
Mike
Quick Reply: which layback license for detachable tourpak?
