Built the best engine cooling system...again
#471
I'm using mine with the different shaped Bar and Shield Harley horn cover and it works fine with no modifiication other than having to cut the bottom screw down by 1/8"
I have a question for anybody that wouldn't mind looking at their stock horn installation and answering it though? Which way is the back side, closed end of the clip that holds the horn wire oriented? Towards the front cylinder or rear? When I put mine back together, I oriented it so that the closed end of the clip faces the front cylinder which allowed me to do a good job of hiding the Fans wiring connectors. However, the horn wire and clip seems to be too close to the cylinder head. Don't want to be melting any wiring. Its about 1/4" away. I cannot remember what the clips stock orientation was, only that the clip was on the top mount bolt. Appreciate anybody that would let me know how their stock clip is oriented. Thanks, Rick
#473
#474
#475
#476
Good thinking! I hope you are not affended easily if someone offers you a suggestion? The icing on the cake on your very creative install would be to replace that series of nuts that you are using as a spacer with a polished piece of thick walled stainless steel pipe. Or, my Harley dealer has a bin full of chrome spacers of various lengths. I think most dealers do? That would be the icing on the cake I think! Good job!
Here are some photos of my install with the Rivco horns. I don't have step by step, just the completed. I'm planning on covering the nuts with probably a piece of stainless braided hose. (I hope the photos work!)
Attachment 254724
Attachment 254722
Attachment 254725
Attachment 254723
Attachment 254727
Attachment 254724
Attachment 254722
Attachment 254725
Attachment 254723
Attachment 254727
#477
#478
#479
BTW, how did you get the stock bolt out? I made a feeble attempt recently and it wouldn't budge, but I didn't try very hard.
#480
Good suggestions on the spacers. That's why I've been planning on covering the nuts with the stainless braided hose. But I like the spacer idea. Thanks!
There is some bouncing, however. It is the most severe at idle. At higher RPMs, it's fairly smooth. I expected some movement, given the physics of extending the horns. I'll need some more ride time to see if this is really a good solution.
I'd love ideas to improve this mount, especially as regards bouncing/vibrations. Thanks all!
Jason, I love the product. Thanks for your hard work!
