any other tools i need?
I am going to do the chrome front end kit on my 07 sg this week. I am also installing progressive monotubes at the stock height. I have scrolled through just about all the diy threads on the chrome front end kit. I haven't seen much on the diy monotube install. I found one thread that no one replied to. So my question is are there any "special" tools that I will need. What I have so far are: homemade extra long 6mm allen head socket, 2' lenght of 1.5" pvc pipe and the axle wrench. I also have a vice mounted to my work bench. For those of you that have done this, am I good to go with what I have for tools? I have the bike pretty much ready for tear down. A friend of mine is coming to help me with it this week so he can see how it comes apart and goes together as well as giving me an extra hand. My main concern at this point is the springs and compressing them.
I didn't put in monotubes but when I did my chrome front end, I was able to compress the factory springs by hand. I may be doing monotubes or Race Tech springs next year, so I'll be interested in your install and results.
Instructions found on the net show no spring compressor necessary for install......
I put new bushings and seals in a set of take off lowers I bought on this forum. One of the 6 mm screws in the bottom of the old lowers stripped the allen socket they are pretty soft material. I drilled the head almost through with a bit that was a little larger than the screw shank and then smacked it with a drift punch to break the head off. It took about 10 extra minutes but worked well (5 mins was deciding what to do). Be sure and buy new screws before you start. As recomended by the SM I use an air speed gun to tighten and remove these screws and it works good. I have not tried it without an air wrench so can't say how well that will work.
I could not get the springs compressed and the plugs started by myself but a neighbor helped me and it went easy with 4 hands. I used my bench vise with copper jaws. The tubes were at a slight angle and about chest high so that didn't help trying by myself. I put a 1 3/8" socket on a 1/2" drive ratchet and while he pushed on the ratchet I could turn it and get the threads on the plug started. The PVC pipe worked great as a seal driver. I stacked 3 or 4 1-1/2" couplers with the stops filed out and did not have to split any pipe. The HD manuals were right on except the quantity of wear rings on the dampner tubes. SM said it took 2 per side the parts cataolge and dealer said it took 1. I bought 2 per and it took 2. Keep it clean and all should go well. Good Luck
You will need an impact gun. I cant rememebr the size wrench for the top, I used the box wrench in the tool bag that came with the bike. I think its 36mm? Make sure you take the lowers off with the forks still in place. It will be much easier. All the ideas you got so far work well. Now is the time for a flush mount axle as well. Good luck
Yep, it's just nuts, bolts and circlips. About the only real complex part is measuring the new oil properly. Ya don't really need the special Harley tool to do that. Just a long screw driver that you can put a piece of tape on to measure from the top of the tube to the oil level.
