Will Ultra fit in 5'x8' UHaul trailer?
Recommend you go with the Uhaul 5x9 ramp trailer like the one funnythebunny posted. Last summer I used the 5x9 trailer to haul my SG from Nebraska to Delaware and back. The 5x9 is a little heavier compared to the 5x8. Also, the 5x9 has the built in front wheel chock if you need it and the larger ramp is way better for rolling the bike in and out.
5X8 Cargo..
Dimensions
Inside dimensions: 8' x 4'8" x 5'4" (LxWxH)
Door opening: 4'0" x 4'10" (WxH)
5x9 Utility Trailer with Ramp..
Dimensions
Features
Lowest deck
Softest ride
Easy towing
57" wide spring-assisted ramp
Galvanized finish
Multiple heavy-duty tie-downs
Integrated Motorcycle Chock in newer models
5X9 much better for your needs,I'm a U-haul Dealer
Dimensions
Dimensions
Features
Lowest deck
Softest ride
Easy towing
Galvanized finish
OK, I am not trying to be a smart Azz, but since you have a Ford F150, why don't you just put it in the back of the truck? Even with a 6 foot bed the tires will be sitting on the bed. You will have to leave the tailgait down though. I just hauled my Ultra in the back of my Chevy Silverado this morning.
Bike's too long for and 8 foot trailer of any type. It might just fit in there, but there will be less than an inch or two between the back door and the rear surfaces of your bike.
I don't recommend it at all. Instead, use that open Uhaul. And while you are at it, get a real hitch for that F150 for pete's sake.
