Is this Common?
Is this Common?
When I took my bike in for it's 5K service, the dealer called and said the primary gasket was leaking. I didn't question it because I had my compensator replaced under warranty at the same time.
So I take it in for 10K service and brake switch recall the other day. When I picked it up, I noticed the invoice had warranty work for primary leak again! I know for a fact that there wasn't any leaks, because I checked it frequently! They also replaced the shift shaft seal. Are they just ripping MOCO for $. Just wondering if this is a common practice for most dealerships?
You didn't read what he said...he said it was not leaking and but they charged for a change anyway. But really who knows whether or not they really installed a new gasket. Unless you watch every move, you never really know what a dealer's non-service dept installs or doesn't install. It's really sad how sh!tty some service departments have become.
You may think this sounds funky but; The next time you take it in take a sharpie marker and put some small (hardly noticeable) marks on one of the bolts and the stationary surface (chances are they won’t put the same bolts back in the same hole). To really make sure, just put some whiteout (or some white paint) in the bolt head. If they take a wrench to it there should be some dirt, markes, etc., get the point? This is on way to see if they are telling the truth. The other way is put a hidden camera on the bike or call in Jack Byrnes ,
They don’t call them stealerships for nothing I guess… You never know what they are doing. That’s why I try to do basic maintenance myself, just don’t trust them all that much.
