OE vs Halogen vs LEd chart comparison and cost
Gathered the bird's eye view lighting charts for OE, Halogen and LEd headlights ( see attachment). Also, included cost from the HD website. Looks like for the money the Halogens are the best deal. They cover longer distances. The Leds are only wider in the first 100 to 300 feet. I thought this would be objective data and would be better than personal opinions.
someone did tests with hd led vs trucklite led vs halogen.
http://www.lrsanitary.com/0/leds_update.pdf
rather than ( like most) taking a picture of the front of the bike, they took photos of the light from the bike shining down a road
the hd led had the best result ( to my eye) although the tester preferred the trucklite
I liked the pattern, coverage and color temperature
The HD reflector with halogen is awesome compared to my older bikes...so I'll stay with that until the price on a quality led comes down to realistic
mike
mike
One advantage I see is the LED light although was shorter in length than the halogen, it was around 50' wide compared to a 30' wide beam, thats 20 more feet of friggen deer space you can see. Another thing not mentioned a led is a lifetime bulb, so although it is initially more cost, you may never have to buy another bulb again.
On a side note. Are you sure that middle bulb is not supposed to be listed as a HID not halogen? Halogen bulbs are cheap...Either way my comments still are the same.
l.e.d. vs. halogen
Running a halogen headlamp and H.d. L.E.D. passing lamps(the ones on either side of the headlamp)might be better. You will be seen better during the day with the halogen headlamp(from the sides)and get extra bright at night with the halogen headlamp and L.E.D. passing lamps on together. Just my opinion...plus save$$$.
http://www.harley-davidson.com/en_US..._High_Beam.pdf
Here is description of Dual Bulb.
http://www.harley-davidson.com/gma/g...bmLocale=en_US
