How do I change the windshield on my SG
RE: How do I change the windshield on my SG
Its very straightforward and simple. Just remove the allen head bolts on the front of the fairing, right below the windshield and pull up on the windshield with a little of a rocking motion. The main thing to watch for when you put it back on is that you don't overtighten the bolts. The bolts go into an insert that is mounted in plastic. If you tighten too much, the inserts will pull out. Finger tight is fine. If the windshield squeaks at idle, just loosen the bolts, readjust the windshield and retighten. Good luck.
Previous 2 posters were correct... Heres a link to the long version Installation Instructions from the Fast Aire web site
http://www.fastaire.com/windshield-install.html
Reno
www.FastAire.com
Reno
www.FastAire.com
I did the fastaire way...don't totally remove the bolts. loosen the 3 in front, and loosen 2 in back. pull the old shield out. I peeled just enough of the stuff that came on the new windshield to get it seated. after tightening the 5 bolts, i then peeled the rest of the protective paper off....no scratches!
Jimbo, that photo looks suspiciously like a new-bike photo from HD of BR. Here's mine, bought 11/22/06. It's Black Cherry, which is hard to tell in the photo. Haven't seen you around, but I'll be looking.
[IMG]local://upfiles/4327/1C9F08AFE49E4BFC82265CBECC385C52.jpg[/IMG]
Yep, it came from HD of BR. I almost bought the Black Cherry SG. Something about the Cobalt Blue that kept catching my eye.
I ride the River Road every afternoon after work from Geismar to over by The Cabin, back up to Gonzales, back to Dutchtown, just to clear the cobwebs.
