2008 Street Glide Stereo
Adjusting AVC
See L in Figure 4. Automatic Volume Control (AVC) automatically
adjusts volume level to compensate for ambient noise
associated with motorcycle speed.
If the AVC does not adequately compensate for ambient noise
(or if it over compensates), enter the audio setup menu and
select AVC. Compensation is adjusted with the AUDIO switch
on the left hand grip. Using left thumb, press the AUDIO switch
up (+) to raise the compensation level or down (-) to lower the
compensation.
NOTE
Although the receiver AVC is preset at 3 bars, it is adjustable
from 0 bars (OFF) to 4 bars. At 1 bar, the volume does not
change with motorcycle speed. The more bars displayed, the
higher the volume increases with speed.
compensation.
NOTE
