tbw lost all response
TBW issue
Yesterday talking to my indy, he mentioned he knows of several instances of the exact TBW issue you mention. In every case ignition off and on has cured it, and he believes the moco is aware and working to solve it.
Luckily no issues with mine yet.
Some of them happened while riding, engine went to idle....
You didn't mention the year of your bike, if it's 08 or 09 there is a fix for it for about$ 40 at your local dealer due to some minor parts upgrade.Parts I think about $3 but half hour labor what gets you,IMO it should be a recall but I don't know how Moco gets away with it if it happens with any other automobile I bet you it will be a RECALL.
Did you check for codes? I had a problem with mine like that and it ended up being a broken wire at the throttle body, black and white wire for the sensor grounds right at the connector to the throttle body. Do a search on here and you will find the service bulletin that will help you troubleshoot it. Codes are important to differentiate between a problem with the twist grip sensor or the throttle body actuator and sensors.
It is much easier to find neutral on these things if the engine is not running, so I kill mine in 1st, and then just click to neutral and watch the indicator.
I did this on the Heritage for a while, but I discovered that if you kill it with the thumb switch, and the ignition is on, you will still get the neutral indicator.
Basically let out a little on the clutch as you shift for neutral. is that what you are referring too?
