Does anyone know if a 09 touring front wheel and tire will fit an 08 roadglide...is the axle the same? are there any mods needed to have it fit? Thanks Joe
According to my '09 Part Catalog, the front axle part number is 41547-07A.
The sleeve and spacers are -08 part numbers.
So the '09 wheel should fit, at least the '08 Touring models.
Any 2008-2012 wheel is interchangeable as long as the wheels are the same as far as ABS & non-ABS goes. If you are going from ABS to non-ABS or the reverse all you have to do is change the left side bearing. The 08-12 wheels will fit all 00-07 touring bikes as long as you use 08-12 spacers & axle, the lower legs haven't changed since 2000.
I have an 09 rg with the aluminum 2million spoke rims. If those are the ones youre talking about. FYI, pain in the a$$ to check the air with dual calipers. The valve stem in directly in the middle of the wheel pointing straight towards the hub. And hard to clean too
