thinking 21
thinking 21
search function won't work for me the last few days and I know its been talked before, I have 02 rk and leaning for a 21 seems like I remember some post about having to re drill the rear holes on newer bikes is my 02 the same way or will it fit without any mod. also my se came lowered an inch from factory will that be enough to counter the extra height I put on 2-3 ohlins so that raised the rear a .5 or so I am thinking that be around a inch higher in front does that sound ok
I would say your probably fine on the height, but that depends on the look you like. I personally like the frame to run about 1/2" higher in the front. I assume by drilling you mean't the fender holes. Usually can either drill larger or dremel the holes to oval a little and get the fender to rock. Tape some closeline rope around the tire and check for clearance. I've had some work without drilling but always check, you don't want to have to repaint a fender just cause you didn't take a little extra time. Good luck.
kyleplusitunes
03-24-2012 05:37 PM
