throttle lag ?/?
Old 11-22-2011 | 10:12 PM
sweetglide103's Avatar
sweetglide103
Default throttle lag ?/?
i have another question........i have a 2011 103 streetglide with the pro 103 upgrade kit installed......( se259e cams...10.5 to 1 pistons.....etc.)....as well as i had installed some new pyo monkeybars......and had new chrome mastercylander and cables ran and grips.....but i am noticing as i crack the throttle.....i notice a lag from hearing the motor rev....to seeing to the rpm rev.......im wondering if the throttle position sensor is not working properly....i don't recall this before on my other bike.....buts its definatly noticable.....not really feeling it in the bike from when i rev the throttle....just seeing it in the tach.....any thoughts ????
Old 11-23-2011 | 05:35 AM
sweetglide103
i read over what i wrote....not as clear as i thought...but when i open the throttle......i hear the engine rev....no hesitation....the hesitation is at the rpm gauge......
Old 11-23-2011 | 05:42 AM
Freebee's Avatar
Freebee
The tachometer is not synchronized with the actual engine RPM ??
Old 11-23-2011 | 04:37 PM
sweetglide103
so is this normal or should i be taking this back to the dealer ???
Old 11-23-2011 | 05:20 PM
Freebee's Avatar
Freebee
No it is not normal.. The tachometer should not "Lag" behind the actual engine RPM !
Old 11-23-2011 | 05:24 PM
sweetglide103
do you know what the possible cause could be ???
Old 11-23-2011 | 06:27 PM
Scuba10jdl's Avatar
Scuba10jdl
Faulty pick-up unit for the tach maybe.
Old 11-23-2011 | 06:37 PM
sweetglide103
could that have anything to do with either the motor work i just had done...or the new handlebars ????
freashman06
07-11-2022 07:42 AM
Caine01
08-23-2015 02:23 PM
shurtman
10-20-2014 08:28 AM
Dynarider04
05-30-2011 03:54 PM
97WG
Exhaust System Topics
09-06-2010 07:46 PM
Quick Reply: throttle lag ?/?
