Rockford Fosgate PBR300X4 amp install
I am in the process of putting in this same amp right now. I am using it to power 4 JL Audio C5-650 speakers. My bike is getting raked right now so im a couple days away from getting it all powered up but after tonight, its mostly all wired. Here is a quick pic....not trying to hijack.....just want to say that it seems like alot of bang for the buck out of an amp. Small, powerful, etc
With all the pre-hype, and pushed back release dates,.........it seemed as if everyone was in for a let down. Glad to see that the guys that went this route are satisfied.
Stereo companies don't realize that the 'bagger nation' is a viable, marketable commodity !!
Good luck to everyone on their installs !
Been reading about this amp a little. Does anybody know if the 2010 HK head unit is designed for 4 Ohm or 2.7 Ohm speakers. I was thinking my stock speakers were 2.7 ohm, may be mistaking there. Would it matter about the HK unit as long as the speakers being powered by the amp were 4 ohm? Or would the head unit need to be 4 ohm also? In other words,,, if the stock HK unit is a 2.7 ohm unit, will it overwork the HK unit plugging it into a amp that is rated for 4 ohm? Or could doing that possibly damage the amp?
I have installed two of the pbr 300x4 on my 09 Road Glide. Using the amps to push 4 Rockford Power series 6.5's and a set of Rockford Power series 6x9's in a set of cycle sound lids. this combination is unbelievable!
For the money the PBR300 and Power series speakers are the way to go. I had a hawg wired system and it didn't compare to the rockford.
