Has anyone installed Ohlins on 1" lowering blocks?
I know my fellow Ohlins users are gonna blast me on this one. NO I have NOT done this and I don't have any plans too, but has anyone installed Ohlins on 1" lowering blocks? I personally think it will destroy the shock because of the angle of travel that it was not designed for, but I was curious if anyone has done this yet?
Thanks guys!
gr, I did get the shorter Ohlins and I'm not going to do the lowering blocks on my Ultra whereas it is my every day bike. It just crossed my mind so I posted the question to see if anyone has done it with the Ohlins. But all in all I wouldn't do it with these shocks, especially since I have the #2-#2A (12 1/8" length).
I'm getting ready to start a custom on a street glide 06 and was just thinking hmmm I wonder if.... But after reading tj's post it sounds like I could do it with a #3-#3 with a 1" lowing block on an 02 and up with out changing the angle of the shock. That's really the info I was digging for.
Thanks guys!
As you can see that you (2009 Current FL) have only 8.75" or 8 3/4"when the bike is as far compressed as it can possibly be before the swing arm hits the frame.
This means that you have 0.167" at full bottom out clearance before hard parts hit. The tire does not hit the fender on the 2009 ~ Current.
In your case with a 2007 stock bagger, the tire hits the fender first as no hard parts would hit with the exception of the shock (bottom out).
Howard,
I'm glad you chimmed in here. For clarrification purposes, I'm not wanting to lower my 01 Ultra with the installed #2-#2A any further. I'm completely happy with the ride and the look. and if I was thinking about it, I'm not anymore after your explination, which was quite thorough.
BUT! I am looking at customizing an 06 street glide which I want to lower.
So if I were to use #3-#3 12 3/4" (329mm) and subtracted the sag of 25.66 which leaves 51.34 of the 77mm stroke. If I subtract 51.34mm from 329mm the shock would be 277.66mm or 10.93" fully compressed. Then if I subtract 1" (25.4mm) for the lowing block, that would leave me 252.26mm or 9.93" fully compressed.
So if I hit metal at 8.75" (8 3/4") - 9.93" = that would leave me 1.18" (1 1/8") between compressed shock and basically bottoming out right? or will I still hit the fender?
This bagger custom will be for looks, but I still want function. It will also be for solo only riding. I like the Ohlins so much that I don't want to use an air ride system. Bottom line is, will it work and keep the fully intended use of the shock?
EDIT: If I'm correct I could go with a 2" lowering block and still have .18mm to spare correct? (not that I would ) Straighten me out Howard!
For explanation sake I used a 2009 frame because I had the photos ready and easily posted, little work to me. The 2006 has less drop than the 2009. I showed you haw to make the calculations and verify it. Do not take anyone's word for anything, measure yourself. If my memory serves me correctly, on a stock tire the tire hits the fender at 9" ¢ to ¢ of shock bolt holes. Your results may vary. Jim, if you wish a small shock than think about a small stroke shock and lower it. You do not need all of that lowering block stuff if you are handy and can think. Lowering blocks are just a way of selling something out of the package. I will give yo0u a hint, turn over your swing arm, been doing that a while but you must space out your shocks because they will hit the swing arm if you do not.
