Lost rear brake coming down mountain
Cromagnon, I am not an expert by any means but I do need to ask about your switching from dot4 to dot5 brake fluid. It is my understanding that if a brake system is not designed for dot5 fluid you should get that stuff out of there 'immediately'. Dot5 fluid can corrode systems not specifically designed for dot5. That may or may not have contributed to your most recent system failure but it will surely contribute to one in the future. Look at your owners manual or the cap on your reservoir and only use the fluid specific to your bike.
Etstrine and rkoivisto had the best answers.
Checked the level and it was low. Also guy at Autozone where I picked up some fresh DOT4 said 4 & 5 together causes evaporation ... I'll take his word for it since it was low. Completely flushed it out ran about 2 pints through the bleeder, then brought it up to level. Should be OK. Thanks everyone ... good learning thread I guess
Exactly what I was thinking....besides...the fluid only pushes the calipers out to apply the pads to the discs.....maybe he glazed the pads??? I'll have to read up on this one. Glad the OP came out of it safely and thanks for posting!
Was riding the Blue Ridge Parkway on Saturday. Was a blast, most of the leaves were already down, so hardly any traffic. Oh yeah it was cold too. Anyway had the wife on the back and was zipping along pretty good. Decided to exit the Parkway at Afton mountain. Coming down 250 decided to jump on Route 6 which twists and turns down the mountain really steep. After a couple of wild turns hard on the brakes, my rear brake went out completely. My wife could tell there was something wrong, I used the engine and the front brake to come to a stop. Turned around went back up the mountain and got back on 250 where it's pretty much a gradual descent.
After a while I managed to pump the brake back up. Must of overheated the brake fluid and foamed it up.
My question is, after 2 more days of riding on flat roads, the brake seems to be working fine. Should I be concerned and replace that fluid? I put Dot 5 synthetic in the last time I changed the pads.
I did the same thing. I used DOT 4 in my 2002 Ultra and it needed DOT 5. The fluid jelled up. After getting back home I flushed it out with DOT 5 and it worked great till I traded it in on my 2011. The 2011 takes DOT 4. I think DOT 5 is silicone based and DOT 4 is alcohol based. They won't work together. I was a mile high when it happened on the Cherohala Skyway in TN.
http://www.cherohala.com/
