Only 3qts came out
Old 11-13-2011 | 04:53 PM
Eric Moore's Avatar
Eric Moore
Originally Posted by TUCCI
So how do you keep all the oil from running completely out then? Or are you filling the oil tank as its running the old oil out?
follow the same steps as the scanenge sysyem.. but you dont remove the oil filter till your finished.. add a qt of oil to the tank after you drain it.... if the return line stops pumping oil stop the engine then... I never have to run the whole qt through... to get clean oil out of the return line...your just flushing out all the dirty oil & replacing it with clean oil.... its really simple.. then remove the oil filter & install a new oil filter & continue like normal.. now if you havent done this it may take more that 1 qt to flush your system.......depends on how dirty it is..you can buy the oil scavenger or save some $$ & do it this way..eather works fine..nuttin wrong with the scavenger...
WNMORE
02-04-2013 10:30 PM
HDV-GLIDE
02-23-2012 07:17 PM
Ronp42
05-23-2010 12:35 PM
kahaone
08-17-2009 06:19 PM
Silvertip
Oil Archive (no new posts)
01-14-2008 05:13 PM
Quick Reply: Only 3qts came out
