HCC 12" ape install help
Old 11-12-2011, 05:26 PM
cihjr1408's Avatar
cihjr1408
cihjr1408 is offline
Default HCC 12" ape install help
Hey everyone. After spilling gas all over my garage I have stripped the bike down to where it needs to be. Or so I thought. Do I have to take the inner fairing off to get to the handle bar clamp? I can access two of the bolts but cant get to the others. Any tips would be great. Thanks in advance.
Old 11-12-2011, 05:33 PM
PistonPuller's Avatar
PistonPuller
PistonPuller is offline
I did not remove the inner fairing. I took out the radio and I cut down one of my allen wrenches until it fit.
Old 11-12-2011, 08:36 PM
racersg's Avatar
racersg
racersg is offline
Hello,
You can get to the 2 bolts with out taking the inner fairing off like above said, you can cut down a wrench so it will clear the fairing. It depends on the tools you have avaiable. You can use a torx bit and a wrench. Just take your time. Once you get it broken loose, use a ball end Allen wrench, it works like a swivel.
Good luck.
Old 11-12-2011, 09:34 PM
HighLiner's Avatar
HighLiner
HighLiner is offline
Watch the install video on LA Choppers website. Looks like a good time to do a painted inner fairing!
Old 11-12-2011, 10:39 PM
Texas Fat Boy's Avatar
Texas Fat Boy
Texas Fat Boy is offline
You don't have to remove it. But you may have to loosen it.
Old 11-13-2011, 07:22 AM
glide2005's Avatar
glide2005
glide2005 is offline
I have installed two of HCC bars. Have not remove or loosened the inner fairing yet. Just remove the radio as said above. The plastic piece that runs under the radio will flex enough to remove the bolts . Besure to tie the bars up or lay a blanket across the tank to prevent the bars from falling down and missing up paint.
Old 11-13-2011, 07:51 AM
cihjr1408's Avatar
cihjr1408
thanks for all of your help, time to get started.
Old 11-13-2011, 07:56 AM
cihjr1408's Avatar
cihjr1408
Old 11-13-2011, 10:26 PM
HighLiner's Avatar
HighLiner
Where's the pics?
Old 11-14-2011, 06:42 AM
BDHABT's Avatar
BDHABT
BDHABT is offline
Why did you spill gas?
Did you have to remove the gas tank?
Quick Reply: HCC 12" ape install help
