After researching the HDF I pulled the trigger and had the cam chest upgraded to hyd and added the 203's. This combination rocks, pulls hard right where I like to ride, no downshifting on hills or to pass. It also seems to be getting better mileage. And NO POP on decel, which previously I thought was normal. Best mod so far!
****Had bike dyno tuned today by a guy who really knows SERT right here in the 661, printout attached, AFR was fat in mid range which I'm hoping was causing my reduced mileage. She pulls hard 74 hp and 85 tq.
Did you dyno tune it? Programmer? Doing 203's & cam plate on my 00 in a couple weeks. If funds allow will install 06 or newer heads & 95".
If you have not bought the 203 yet , seriously look at the 204 instead. The 203 are a EPA compliant cam and you are doing all the work for a minimal return. The 204 will pull a lot stronger at all rpm than the 203.
I used 204 in my 05 Fatboy and they were great improvement. Im looking at cams for my 103 RG and Im leaning towards the 204 again ove the 255
