Slow speed wobble
Slow speed wobble
I just got some E 3s on my 09 Ultra and now I get a more pronounced wobble around 25 - 30 mph. It has always done that, and as I have heard the dreaded response of "they do that" , now its a lot more noticible. Used to be solid on a highway clover leaf (at around 30 mph) but now wants to shake in the turn.
The weird part is, the indy says he doesnt' use wheel weights at all but I found one on the rear. I had the wheels powdercoated and new tires at the same time. Its been to the dealer once since, but not for anything to do with the wheels.
Neck bearing test stops on the third swing.
Indy mounted the tires with a static balancer, taking the front wheel and tire back today for a re check. Guess the next move after a test ride, it it stlll wants to wobble, would be take it back off again for a spin balance?? Can the rear wheel balance affect the front like this? Would dyna beads be an option? Can't figure it out..........yet
Hope someone can give me a better idea
Thanks
Thanks
Couple ideas; you have 2 new tires, it is not impossible for one of them to have a defect that causes the wobble. More likely it's the balance, it sound like your balance condition may be a little wishy-woshy, I don't understand how someone claims to static balance, but doesn't use weights, and then you found a weight. Do yourself a favor and get the tire/wheel assembly spin ballanced by a reputable shop. Beware that many shops will not take the time to properly R&R your drive pulley and rotors when changing tires, correctly torquing those items is critical.
...and balance is not alway only at one place on the circumference, but can also be heavy, or lighter on one side.
examine the tire for markings of a factory second or defect
and yes, tires need to be spin balanced
if you raise the tire up and spin by hand, it should stop in a different position each time
mike
mike
mike
mike
Got the same wobble on mine with old tires and with 2 new tires. I am using dyna beads. I don't think it has anything to do with balancing. I think there is a problem with these bikes that the mfr either can't find or does not want to tell the world. Lots of discussion here on the forums but I don't think I heard of anyone actually solving the problem completely.
Could be just the fill from a new tire compared to your old? What were you old? Just put a new one on rear however and it took my low speed in turn twitch away. Most tires and cast wheels need little weight. My Harley dealer dynamic spin balances them. Static unless you have plenty of time is crap. Beads do nothing and are smoke. Do not think balance would cause wobble unless it was real bad. You will fill balance at 60 on smooth road as a up and down bump in bars. Jack bike and spin tire to see if it runs true and even. true = wobble. even = indicator on od or slide a board under it to see if it is same distance away from board all around (crude-really need indicator)
