PLEASE HELP!!!! Bike wont start after ape install
i had same issue guy come to find out i stupidly wired the tps sensor backwards the engine light coming on means there is a error code most likely with the tps i would go over the tps with a fine tooth comb and be absolutly sure you have it wired correctly i thought i did but it was not so
Hold the throttle wide open, turn on the key and see if the fueling cycles like you are used to hearing. Don't start is that way as you will freak out and let go of the throttle, it will open up and ..........
michaelbsilvia
06-26-2012 09:37 PM
