picture of the cat in the head pipe
Old 11-07-2011 | 08:26 AM
mrfikser's Avatar
mrfikser
Default picture of the cat in the head pipe
does anyone have a picture of the headpipe opened up to show the cat...I am going to remove the cat from my bike and I am trying to figure out exactly where to make the cuts when I open it up, I am trying to make as small a "door" in the pipe as possible and if I have a picture showing one opened up with the cat still in the pipe I can figure out where to cut it...Oh, and its a 11 flhrc...
Old 11-07-2011 | 08:31 AM
mrnone's Avatar
mrnone
bet you could find a take off for super cheap and experiment on it instead of your pipe.
probably worth the cost of admission...
can do the whole mod without putting your bike down and if it all goes horribly wrong... big deal. right?
good luck and please take pics I am about to gut mine too.
Old 11-07-2011 | 08:51 AM
coolerman69's Avatar
coolerman69
Just cut it in the middle of the oval shaped section then dig it out in both directions. Be tough to get it out a "door". It would have to be a big door.
Old 11-07-2011 | 09:25 AM
harleycat225's Avatar
harleycat225
Old 11-07-2011 | 09:33 AM
KCFLHRC's Avatar
KCFLHRC
I don't see how you could effectively clean out all the material by cutting a small door in the collector. This material isn't easy to get out. The best way is to cut it in half, remove the material and have it welded back up.
Old 11-07-2011 | 09:34 AM
captwjf's Avatar
captwjf
Search the forum. I just looked at a posted link where someone cut a door into the head pipe. He cut about a 180 decree section out cleaned the cat and rewelded it.
Old 11-07-2011 | 09:39 AM
NDBadlands4-2's Avatar
NDBadlands4-2
I am just getting new pipes this winter to get rid of the thing.
Old 11-07-2011 | 10:06 AM
ACLazer's Avatar
ACLazer
Do a search and you will find TONS of info.
Some good "De Cat" Pics here.
https://www.hdforums.com/forum/tourin...with-pics.html
Cutting the access hole, instead of cutting the pipe in half I'm sure will help keep some strength and integrity of the pipe. This is how I did mine
Good Luck
Dom
Old 11-07-2011 | 10:16 AM
journeyman's Avatar
journeyman
Old 11-07-2011 | 10:21 AM
ACLazer's Avatar
ACLazer
Originally Posted by journeyman
Quick Reply: picture of the cat in the head pipe
