Security System problem.
Old 11-05-2011 | 04:27 PM
MovedtoSyracuse's Avatar
MovedtoSyracuse
Default Security System problem.
The bike won't detect either key fob. Put new batteries. No luck. I don't have the override code. Anyone have any suggestions? I'm at a loss.
Old 11-05-2011 | 04:36 PM
rlaf75's Avatar
rlaf75
Check your owners manual if you have it. That should tell you how to reset your code. Also theres a nice cell phone app out there called "v twin mobile reference" its a free app thats available for android phones, im sure for apple devises as well. That also will help you reset your code. Hope this helps you
Old 11-05-2011 | 06:19 PM
ucommbxny's Avatar
ucommbxny
are the batteries good, and installed properly.
Old 11-05-2011 | 08:13 PM
sgdiesel's Avatar
sgdiesel
Owners manual won't tell you how to override the code if you don't know original - that would render the security system useless!
Not sure why you don't know the code, were you not given it by the dealer? If not, contact them - they should know what it was. If that works - reset it immediately
Failing that, you are stuck and it needs to go back to dealer
Old 11-05-2011 | 08:20 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
once u get the code (or an expensive new code) theres a card in the back of the owners manuel it has a place to write the code and instructions on how to use it,it fits in your wallet like it was made for it.
Old 11-05-2011 | 08:37 PM
zoozoo's Avatar
zoozoo
Your fob has to be working to find out your security PIN #. It's hard to believe both fobs stop working at the same time unless you are close to some kind of radio signal interference.
Old 11-05-2011 | 09:08 PM
fenderzig's Avatar
fenderzig
Oftentimes the security codes are the last five digits of the bike's VIN number at least thats how the original dealer sets them up. Try that...see if that works.
Old 11-05-2011 | 09:14 PM
caspr2's Avatar
caspr2
If not the last 5 of your vin try 11111 or 12121. If you haven't set it up it will be one of those 3 most likely.
Mr_Taipan
09-07-2020 08:06 PM
flynavy
11-27-2014 10:59 AM
hapbob
2014-2023 Touring Models
22
03-28-2014 05:24 PM
rattlebones
11-26-2009 11:31 AM
roadrunner68
04-12-2007 08:31 AM
Quick Reply: Security System problem.
