Tightening compensator bolt
I installed the SE compensator in my 09 Road King(works great),but I didn't use extra lock-tight.I noticed the thread on the bolt had a coating on it.I tightened it up then backed it off like the installations said,then torqued it to the specification.I noticed on other posts guys applied more lock-tight on the bolt.Will I have a problem?Sure don't want to take the primary cover off again next spring. -Thanks
If the bolt already has lock tite on its from factory its fine. Just tq to spec you will be okay.
