Where do I plug in my GPS?
Yup, thats how I did mine. Ran it down the Bars and into the Fairing ![Wink](https://www.hdforums.com/forum/images/smilies/wink.gif)
http://www.ebay.com/itm/190444415932...84.m1497.l2649
Turned out real nice and clean looking too![Smile](https://www.hdforums.com/forum/images/smilies/smile.gif)
Although it seems intimidating to remove the outer fairing, it really is pretty easy to do and once you get it off your options become much greater for hooking up your GPS. I ran the cable for my Garmin along the clutch cable (although to make it easier to get it through the hole I removed the cable, but it can be put through without doing that) then spliced it into the cigarette lighter wires. I just stripped some insulation, verified with a test light the hot wire, then wrapped the wires and electrical taped them. You can also use the shrink tubing, but someday I may need to remove the wires again.
Here is a pic, the rolled up wire is the Garmin GPS cable and you can see the 2 wires spliced to the cig lighter wires down near the bottom of the photo. This is what the fairing looks like inside.
![](http://farm7.static.flickr.com/6020/5998755564_8b918d884f_b.jpg)
