oil level check hot and cold on 2012 SG
Every time I check the oil on my SG either hot or cold its damn near the same on the stick??? Is it because of the oil pan dipstick set up like your car compared to the soft tails or sportsters with the separate oil tanks? If you think about it it should show a little bit higher cold because all of the oil drained down from the heads and maybe a little from the cooler, just a thought the dealer was stumped on that thought. I could see the soft tails being lower when cold because of the separate tanks.
According to the book it should be a full half QT lower (mid stick) then when hot. Mine is about the same either hot or cold just like my pickup truck??? any thoughts....would be so much easier to check cold before a long ride.
The difference between hot and cold is so minor it's almost irrelavent. On mine it's about 3 or 4 dots on the dipstick or approximately 1/8 to 1/4 inch.
1/4 inch on the dipstick translates to about 6.5 ounces of oil. An engine that holds 3.5 to 4 qts. of oil isn't going to know the difference of 6.5 ounces either way.
Guesstimating the oil level, with that 1/4 inch as a reference, based on the temperature is plenty close enough in my opinion.
Look at all the guys (of which I'm not one of) that preach to run your oil 1/2 qt. low to prevent oil carryover to the air cleaner.
The manual says that a cold engine oil level should be midway between the add and full marks on the dipstick. I've never seen the oil level change that much from hot to cold on my bike.
Me either, that is why I posted this question. My dipstick reads a full 1/4 low from the full hot mark when cold. Everyone tells me it is over filled, but when hot the damn stick shows a couple of dots lower on the stick from full hot, therefore it really does not make a damn difference if you check it cold or hot at least on these touring bikes. I just wanted to confirm if I am understanding this correctly.
I have seen my oil level increase x2 dots when the bike sets a week. I was just guessing that it takes a few days for all the oil to run away from all the parts. Which makes me wonder if I should put some kind of additive in the oil to help protect the motor on cold dry starts during the winter months.
So one final question so I'm clear 1/4 inch down from full is approx 6.5 oz of oil and if the oil only moves 1/4 inch on the stick from cold to hot when checked, would a 1/4 down on the stick when cold from full be a good judge to keep her at??? last oil level question I promise......thanks
