Installing Woods 555 Cams
I went the same way as you are going until I was able to finally pull the trigger on the 107.
I installed the 555 and several months later the lifters. I can tell you to me the lifters where a great improvement, it seemed to quite it all down. I went with the screamin eagle adjustable pushrods tappered, I see you are in Middleburg, Adamec in Baymeadows had them in stock. I am actually pulling the 555's out this weekend and installing the 777's.
I'm running stock lifters. You should be good. Being your bike is a 2008. I think we may have the "B" Lifters. I have no bleed down even after days of just sitting. My drive train really is not that noisy even with roller rockers. I also gave a extra 1/2 turn when setting up the push rods.
I would inspect and only replace if you see any noticeable damage.
