excessive hard bag "shaking" #2
When you removed the seat you had to remove the seat strap bracket. It is possible it was not put on correctly.
#1 Pull the bag off and check underneath to make sure the rubbers are still on.
#2 Loosen the strap bracket but don't remove.
#3 Put bag back on making sure it falls on the bottom rail in propper place.
#4 Put the pinsm, washer, rubber washer back on into locking postion.
#5 Tighten the bracket holding the strap and pin.
If you don't have the strap on the bracket you will not have to remove the bracket to remove the seat.
Yeah rubbers are there...I just don't understand it...its not like its my first bagger...but I checked alot of stuff...helll the muffler doesn't even move...but this thing shakes like a seizure is happing... so I hope maybe one trick u guys have I haven't thought about...thanks to all u guys...keepem coming
