2011 sg and 40-30 decel wobble
Old 11-01-2011 | 10:35 AM
viperr817's Avatar
viperr817
Default 2011 sg and 40-30 decel wobble
Have been dealing with the wobble on decel from 40-30 since new. I checked fall away spec myself and it was within spec. So Friday while dropping it off to dealer for the recall I told them about the issue. They called and told me it was way loose, hmmm I'm betting they tightened the neck more than the spec...
Old 11-01-2011 | 01:21 PM
qtrracer's Avatar
qtrracer
Maybe you didn't get the cables out of the equation?
Old 11-01-2011 | 02:41 PM
viperr817's Avatar
viperr817
Cables were off.
Old 11-01-2011 | 02:44 PM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
Just curious.... what do you consider spec? You need to have the bike absolutely level and remove the clutch cable, and free the main harness from the steering head . From the PDF below......
4. If the clutch cable or main harness appears to be influencing swing momentum, proceed as follows and repeat
the previous step:
a. Clutch cable: Disconnect clutch cable from hand
lever. Release cable from P-clamp, remove from
inner fairing, or release from cable clip on instrument nacelle depending on model. See 2.25
CLUTCH CABLE.
b. Main harness: Remove the rivet and P-clamp to
release main harness from steering head. Secure
P-clamp with a new rivet when procedure is complete.
3 swings is minimum..... I would go with that.
The all knowing service bulletin http://www.glide-pro.com/wp-content/...djustment1.pdf
Other things to check.... tire pressure ..... front and rear. Get a good calibrated digital gauge. The pencil kind are pointless.
Old 11-01-2011 | 03:35 PM
103 sedona orange's Avatar
103 sedona orange
Good that the dealership found the problem. Let's us know how the B/L switch replacement goes.
Old 01-20-2012 | 03:42 PM
clatterbark's Avatar
clatterbark
6th Gear
Has anyone heard of a revised neck adjustment spec? For example, I read that the RG specs have changed from 2 to 1. In other words, pull the handlebar to the left, let go and it should settle somewhere to the center without reversing direction. I'm looking for the service bulletin number associated with this change. The service bulletin may cover all touring models but I'm also interested in the 2009 Ultra specs.
Old 01-20-2012 | 03:47 PM
shooter5074
See my post above
Old 01-20-2012 | 03:52 PM
stro1965's Avatar
stro1965
My '11 Ultra neck bearings were tightened down to the new Road Glide spec. Made absolutely no difference, still wobbles and drives me crazy.
Old 01-20-2012 | 04:14 PM
bagman1's Avatar
bagman1
It has been my experience that the adjustment per the manual may not always be enough, I have always had to go a little tighter to get right. If you have a mechanics feel for a smooth adjustment without binding it is good to go, just like they did when you took it back in. For liability reasons they probably will never tell you that, but I know in the real world of repairing things a lot of times you have to go beyond what the book will state.
Old 01-20-2012 | 09:46 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
everytime i got the 30mph wobble it always goes away with a new front tire?u can balance a brick doesn't mean its round.
MikeRX
02-13-2021 03:58 AM
seniorsuperglideE8
05-29-2014 11:23 PM
Buckinfitch
01-17-2012 07:26 AM
thundergod
09-13-2011 09:24 PM
Agent777
04-09-2011 11:48 AM
