Dealer screwed up my brake light switch recall
Replacing it is the right thing to do, however the "flaw" should have been identified befor sending the customer down the road, a QA/QC inspection folowing a cleaning and test drive after the switch replacement and bleeding proceedure would have revealed the leak. He didn't drive it in leaking, the tech overtightened the bleeder. Bottom line they did a half assed job, you always verify the integrity of the repair when you work on a vital system such as brakes. When you pay a premium dealership labor rate, there is a certain expectation of a professional maintenance service to go along with it. I agree a controlled substitution would also be the right the thing to do, to get him back on the road after they screwed up, nothin personal just the way it goes in the maintenance world.
So you'll know if there's damage. Make sure to clean all the residual fluid off of everything. I wonder if they warped the cap by overtightening it.
That's why I plan to have my bag ( hard bag) off when I take it in. The bleed nipple is directly behind it and there's too much that can happen to those bags once their off the bike. They are top heavy and if not stored properly can tip over onto the floor......too much can go wrong.
Anytime you "open" the system it needs bled.
Forget about it, paint is considered cosmetic, I've already played a round of nerd bingo with the factory reps regarding improperly cleaned brake fluid that ate all the paint off my control housing after the dealer did my my 5k service. F**K dealership maintenance.
It is my understanding, and I may be wrong on this, but the recall is to relocate the control wire that leads to the switch from the brake light. This is due to the wire being too close to the exhaust, and threrfore, the wire gets too hot.
A clarification would be much appreciated because I dropped the RG off yesterday to have the recall work (whatever it is) done.
So, why are they bleeding your brakes if the switch, or the wire, or the tail-light are affected?
I am with you. I think I will wait a little while. I called the dealer and they said it's a problem from the heat and the cat. When I mentioned I did not have the cat, they said it probably wont be a problem with the switch, but it will show as an open recall not fixed on the bike.
