Notices
Warning, A/M wheel bearings
Old 10-31-2011, 08:44 AM
69cj's Avatar
69cj
69cj is offline
Originally Posted by leafman60
Mine were from china, lol. The bearing shop was surprised that a company like Harley used this poor quality of wheel bearing. They passed it around the office and talked about it. everyone was surprised. "Are you sure that's what they put in it at the factory ?"
The replacement HD bearings were made in the Cech Republic. That's eastern Europe.
Old 10-31-2011, 11:18 AM
leafman60's Avatar
leafman60
leafman60 is offline
I think what's happening is that H-D is buying from whatever source gives the cheapest price instead of one place. Probably come from multiple places. One thing for sure, they don't use premium bearings like Timken etc.
Old 11-09-2011, 10:33 PM
BrianG's Avatar
BrianG
BrianG is offline
Originally Posted by 69cj
Went thru the threads and nothing matched any cheaper or for the same price as HD. Also didn't see a positive match. I think if an industrial bearing house couldn't match it we may be jumping thru hoops.
There is something amiss with this....
No way is HD having custom wheel bearings made for their bikes.
Old 11-09-2011, 11:16 PM
X Iron Butt's Avatar
X Iron Butt
X Iron Butt is offline
Thought I'd save some money and find some a/m wheel bearings. The only ones the bearing house could cross reference were DH bearings # DH-559339-1. All the specs matched and they were 51 bucks for all four. 1" bearings on my 07. All four for less than two at HD. What a deal. Had a failure on the front wheel at app. 800 miles. Replaced with HD. At approx. 1500 miles had one on the rear fail. All my bearings are now HD. HD may be expensive but sometimes the extra cost is worth it. Had to do the job twice and ended up with the HD's after all. What's your time and labor worth. Also the rear bearing started to fail on the way to LA. Luckily it did get me home.
I think your 07 used the 25mm bearing. They are not the same as a 1" bearing.
Old 11-09-2011, 11:26 PM
X Iron Butt
Harley probably buys these from a major bearing manufacturer that has a factory in Check Republic or China or all over the Fn world, They sell 700,000 plus bikes a year x 4 bearings. That would easily qualify for a custom bearing if they wanted it. I believe there is a quality bearing made that will fit it is just a matter of finding it. I am going to call ALL ***** tomorrow and see what they say. Had a good conversation with one of their engineers last week about their starter clutches.
Old 11-10-2011, 02:11 AM
dbell66253's Avatar
dbell66253
dbell66253 is offline
Subscribed, have to change my rear bearing soon, quality matters more than price, of there's a better bearing I'm for it.
Old 11-10-2011, 06:35 AM
captsluggo's Avatar
captsluggo
captsluggo is offline
Talking
Finding the correct size bearing is simple, the newer bikes using a 25mm single row bearing is a (6)205. This size will fit just fine, but as some are finding out, there is more to bearings than just the ID, OD, and width. Most run of the mill 205 bearings stocked at a bearing supply, no matter the brand or country of manufacture, will likely be a C3 clearance spec. This spec is common for electric motors and is looser than standard to allow for heat buildup in that application. Not exactly what I am interested in using for the relatively slow turning wheels on a heavy bike.
The issue is finding the HD spec for their wheel bearings and using an appropriate, or better, substitute. I am reasonably sure HD doesn't have a secret bearing formula or facility, so the first person that finds and posts this info gets a gold star.
DoubleTake
05-13-2020 07:08 PM
Wisco1200
Wheels/Tires
10-15-2017 08:50 PM
saafrican
08-21-2017 04:32 PM
Bushy
06-23-2015 02:20 PM
arnold
11-23-2010 06:33 PM
Quick Reply: Warning, A/M wheel bearings
