Tour Pak Upgrade Lights
I had a Run/Brake/Turn module on my 06 Road King and now want to add same module to my 2011 Ultra Classic. I really liked the flashing lights when brake was applied and then went solid after 4 or so times. But my question is which module do I need now that I have a Tour Pak. I want the Tour Pak lights to flash when brakes are applied and also want the turn signals to also work on the pak. Appreciate any feedback.
This may or may not be what you have in mind. I went with the Kuryakyn Panacea Tail Light, Panacea Front and Rear Turn Signals. I added the Ride Time Technology LED Progressive Scan Tour Pak Lights and their rear and front LED fender tip lights. The rear lights light up when the brake is applied and the Panacea rear turn signal lights flash red a couple of times before going steady. I'm thinking of adding a flasher unit to make all the brake lights flash but haven't gotten around to it yet.
Here is a link to a quick video I shot if you are interested in my setup. At the time I shot the video, I did not have anyone around to step on the brake so it doesn't show the brake lights flashing.
http://www.youtube.com/watch?v=QAdBeS63gjM
not yours
12-02-2017 06:42 PM
jay87LX
05-21-2013 06:31 PM
