garmin Zumo 550
Old 10-28-2011, 09:44 PM
nivensid's Avatar
nivensid
nivensid is offline
Default garmin Zumo 550
Does the fairing mount HD offers work with the garmin Zumo 550? Part number is 92238-09. The book states it is for the 660 or 665 but maybe it works on the 550??
If not, did HD ever offer a fairing mount for this one?
Thanks
Old 10-28-2011, 11:40 PM
jwd98056's Avatar
jwd98056
jwd98056 is offline
The form factor of the 550 is very different from the 660 and 665. It is unlikely they are compatible.
Old 10-29-2011, 03:27 AM
ThunderBueller's Avatar
ThunderBueller
ThunderBueller is offline
The 660 series use a much different cradle assembly. Not compatible. Yes, Harley offered a fairing mount for the 550.
PN #92366-08
I sent you a PM.
Old 10-29-2011, 09:33 AM
nivensid's Avatar
nivensid
nivensid is offline
PN #92366-08
I sent you a PM.
Thanks, ordered it as soon as I saw it.
Old 10-29-2011, 09:38 AM
TurkeyRun's Avatar
TurkeyRun
TurkeyRun is offline
I've installed this kit twice. I found that the hole they ask you to drill in the fairing is too small to get the cable connectors through. I ended up making the hole bigger and then packing the hole with some silicon goop.
YMMV
Old 10-29-2011, 09:54 AM
Guntoter's Avatar
Guntoter
Guntoter is offline
Here is a better alternative than drilling a hole in your fairing. Its the Ram ball mount that mounts at the bottom of your mirror stalk. It puts the GPS right over your handlebar/clutch lever bracket and does away with the unsightly U bracket that mounts around the handlebar or the bracket that mounts in place of the clutch housing clamp. I had no bar mounted mirrors when I mounted mine, but I believe you can use this bracket and your mirrors with no problem.
http://www.ram-mount.com/CatalogResu...5/Default.aspx
Old 10-29-2011, 10:42 AM
Maxcustody's Avatar
Maxcustody
Maxcustody is offline
I have a brand new in the box fairing mount. Won't work with my bars if anyone is intersted PM me.
webbhead
02-16-2014 04:19 PM
UltraNutZ
02-23-2013 08:05 AM
BadPiggy
Touring Parts
01-27-2011 05:14 PM
osolow
06-09-2008 02:14 PM
baltimorebook
04-28-2008 06:30 AM
Quick Reply: garmin Zumo 550
