Handlebar Grip Removal
The newer models, the TBW (right side) you need to undo the switch housing. Make sure you put a small piece of card board int the back of the brake lever to protect the switch. once the housing is apart a gentle tug should be all it takes to get the grip off.
The left side, you should still need to undo the switch housing, then I just used a hair drier and got the grip really good and warm, then started to twist and pull, it takes a bit but it will break free.
Mabe check out you tube it is unreal what you can find for videos on there
Alright did it for you.
http://www.youtube.com/watch?v=eOeRCYT_UBQ
