Arlen Ness Big Sucker and H-D Air Cleaner Trim
I purchased the Arlen Ness Big Sucker (w/o cover) from Dr. V-Twin and I'm about to install it although I have some questions prior to installing.
I am wondering if I am able to use the H-D Air Cleaner decorative collection covers (shown below). I originally planned on using the stock (football) A/C cover although I now have alternate plans.
Is anyone currently using any of the H-D covers with an Arlen Ness Big Sucker? If so would you be able to post pictures so I can see how they fit. Thanks in advance!
![](http://i114.photobucket.com/albums/n268/paulyarredondo3/AC-Cover.jpg)
It should fit, as most of that stuff is made to mount t the air filter the same way, through that center bolt hole---
I'd suggest throwing on the ness first---- then once the filter and backing plate is on, look at that ugly wiring connector on the rear of the throttle body.
the football covers that, other covers may not.
If the sight on the wiring is ok with you ( or you want to buy some kind of accessory cover, then look into getting the air filter cover like the one pictured.
mike
mike
Received 49,317 Likes
I use a Wille G cover over an exposed Big Sucker. Works fine. I'll try to get pictures later. I had to add a couple of washers to "shim" it out a little bit, but a super easy trick and worth it for the look in my opinion. I wish I had pictures handy. But the cover attaches to a mounting piece that the center bolt goes through. The Cover hides the center bolt and is fastened by the 5 hex heads. I needed to put a washer between the air filter and the mounting piece so it would tighten up snug without bending the mounting piece.
Hougz79, if you could take some pics and post that would be awesome. That will help me see what it will look like when using that cover!
Thanks again!
Good luck out there bro and Thank You for protecting our Freedom!
