Arlen Ness Big Sucker and H-D Air Cleaner Trim
while the Ness does not have a K&N brand filter- so far mine has been great and it is a tidy set up- easier install and much less expensive than the S/E.
the benefit of a high flow air cleaner is the lack of restriction for air entering the filter, the air horn ordering air into the intake, and the passages directing the crankcase blow by into the intake
mike
Received 49,822 Likes
that's why I use the football cover
i think kuryakin makes a chrome cover ( they make shiny junk)--- but a chrome cover would draw the eye to it- a flat black cover may blend into the cylinders and shadows better.
If someone wanted to be really cool, the pins could be removed from the plastic block and inserted directly, use a little heat shrink tubing the conceal the wires coming out of the sheath.
it brings clear the realization that many modifications require further mods
mike
mike
Regarding installation, here's a great video demo of an AN Big Sucker installation, from beginning to end, produced by Arlen Ness:
Arlen Ness "Big Sucker" Installation Video
Good luck!
