Docking Hardware for a 95 RG Ultra?
I had a 1995 FLHTC.
removing the tour pak takes about 30 minutes once you have done it a few times.
You could change the hardware on the t/p to mount so it comes off fast, then just have the mount to remove.
If you permanently relocate the license plate and figure out the wiring, you'll be fine.
mike
mike
You can use any of the parts up to 2008 when they changed the frame. The 94/95/96 frame is different than the 97 to 08 frames, but not by much. I had a 94 RK, bought the quick detach kit for a tourpak, and I am still using the kit today on my 08 SG.
The front mounts and the rear hoop mounts fit fine. My brother had a 97 RK at the time, and he borrowed my tourpak for a long ride one summer, and if I recall, all he had to do was mount the front dock point in another hole, he had a choice of two, from where I mounted mine.
If you can get a kit for a 96, it should fit your bike fine. The major difference is that the mounting bracket for the tourpak changed to a different style later on due to a tendency to crack. Can't comment on that, had mine 17 years and it's still fine....
anaya3888
01-18-2014 08:40 PM
