Fuel Moto map for 103/FM pipes/255 cam/.030 gasket...anyone??
Does anyone have a map for a 2011 LTD 103 with Fuel Moto head pipe, Fuel Moto pipes, and 255 cams? I have the Power Vision from Jamie.
I stummbled across a set of 255 cams and was wondering if anyone has this combo and have a map from Jamie. I will call Jamie when I get time, but he's not open on Sundays and I'm bored, so I thought I'd post.
I'm sure Maps with 555/Tw6 etc are all over, just wondering if the 255's are going to require a trip to Jamies dyno.
Also, I plan to have the .030 head gasket as well.......anyone have this combo and want to share results.
Thanks in advance.
Chris
Thanks in advance.
Chris
you need to check your valve to piston clearance using the clay method, before you do this. Valves expand when how and their is a minimum clearance required. you also need to consider future carbon build up and how that impacts the clearance goal.
Thanks for the "heads" up. :-)
