If you were the exhaust nut.......
I dropped one of those small brass ferrules that goes around the end of the throttle cables, inside the throttle housing. It was on the floor about 10 feet away - of course I had the bright idea to lube my cables the night before a ride...found it with the flashlight technique and laying on the garage floor...
Funny how dropped things seem to have a mind of their own.
I had a similar experience happen with a 5/16 socket inside my bat wing. It come of the extension, and fell. I must have spent an hour looking for that socket. First I tried some magnets. That didn't work to well as the magnets grabbed all ferrous metal surfaces inside the batwing. Next I tried compressed air, no luck. Mirrors, no luck.
Looked all over the floor of the garage, in case it fell out and I didn't hear it.
Feeling like I wasted enough time on this socket, i decided to button everything back up, and do a test ride. As I reached the end of the driveway, I heard the socket hit the front fender.
Wish I would have just turned the bike upside down and shook it as another poster suggested. It would have saved a lot of time and frustration!
ok, lets say the nut fell on the belt.... and i moved the bike forward... i guess what im asking is, is it possible for the nut to fall into the crankcase? meaning i'd have to remove the cover, etc? i wish i had someone close by to help me out. should I just replace the nut, finish the install and just take it for a test ride?
It could get lost behind the primary cover, but would likely fall out. If you're worried about losing one of flange nuts down into the frame, just lay a shop rag over the transmission to catch it.
has anyone ever dropped the flange nut into the exhaust port? ie, into the motor? If so... how did you manage to get it out? What happens if you drop it in there?
I'm 99% mine fell in some crevice on the motor... when i get home tonight i'll use a magnet on a stick to poke around. To make sure, I put my finger inside the exhaust port and I didnt feel anything, felt like it was impossible to fall in there because the hole was plugged up with whatever is supposed to be in there (not a mechanic...don't know motorcycle motors that well....yet).
Thoughts?
The guy at the Harley Dealership said not to worry too much about it. Said there was no way it could actually end up inside the motor... it'll probably fall off when riding (shake loose). He said, just put a new flange nut on there and finish the install of the propipe.
Thoughts?
Got it!
Went to Auto Zone, picked up 2 things.
1.) A long bendable light probe
2.) A retractable magnet stick thingy
Stuck the magnet stick in a spot where I suspected it might be but never could get my fingers in.... and boom... I heard a "click" sound... like something had just stuck to it. Then stuck the light probe into the area, and sure enough... I GOT THAT RAT BASTARD NUT! Woooohoooo. Now I can finish my 2into1 propipe install!
Dew Me
08-24-2013 11:52 AM
