Lost XM Radio Signal
Had the same issue with signal droping going down tree lined roads. They resent the signals, I check connections, .....no luck. After my contract expiered, I told them I wanted to cancel. They wanted to know why, told them everything that I had tried. Now they call me or email me weekly wanting me to subscribe at a half the price I paid them originally.
Coastrider here.
Good replies so far. The XM unit I have is the integrated Boom Audio SiriusXM Satellite Radio Kit, HD Part No. 76404-06. My dealer mechanic says it does not have an antenna that can be repositioned, but when I look at the picture of the unit in the HD catalog there appears to be a separate antenna.
I'm riding a 2011 FLTRX.
You have an antenna on the inside of your fairing by your left speaker on a little metal bracket.
It is held on by a magnet on the bottom of the antenna.
I read where one guy's bracket lost a mounting screw and it fell forward and he lost reception heading north because the antenna was pointing down.
Now my experience:
I bought that X-M unit in 2008 for a Street Glide, it worked well and seldom dropped a signal.
I traded bikes for a 2009 Street Glide and swapped it over and it seldom dropped a signal.
I traded again for a 2012 CVO Street Glide and once again swapped it over and it dropped signal so much it was almost unusable.
I moved the antenna to outside the fairing and it now works better than it ever did.
I stuck it between the windshield bags and it can hardly be seen.
Now my experience:
I had the same problem with my antena "puck" and moved it to the outside; however, I fabricated a mount (metal base with tabs) and placed it horizontally between the fairing stabilizer bracket (vertical bracket to the left and right of the radio) and the speaker, placing the "puck" directly beneath the top edge of the fairing. Reception has been great ever since. I think placing the "puck" on top of the radio creates some RF interferance.
My XM Radio loses the signal whenever the bike is pointed north. Any ideas about how to correct this?
Thanks
Thanks
