Is 45 to high/normal ??
Old 11-27-2006 | 12:59 PM
mark2004RK's Avatar
mark2004RK
Default Is 45 to high/normal ??
Had a PC111 and V&H 2&1 installed few months back and popping[!!!] real bad at decel. Some of you might remember my post? Had a chance to take it back to the tuner last week. He reduced the popping consideable. However the first column at zero throttle position is 45 at almost all rpm ranges. Is this normal ?? The tuner commented it was unusual; but every bike different. What do you PC111 experts think? Thanks!!
Old 11-27-2006 | 05:04 PM
jmxp's Avatar
jmxp
Default RE: Is 45 to high/normal ??
I'm not a PCIII expert, but that seems extraordinarily high to me. What's happened to your gas mileage?
Old 11-27-2006 | 07:22 PM
whateva's Avatar
whateva
I had the same problem. Mine stopped popping at 10. I have heard of other people having to go to 15 but 45 seems high. I wonder if you have an exhaust leak or something. If it runs good,,, run it.
Old 11-27-2006 | 07:41 PM
Gutman's Avatar
Gutman
Mark, I have tuned plenty of PC USB's and I start at 10, have had some as high as 50. Chances are you have an intake manifold leak or exhaust clamp leak. Be sure that the first column does not go below 1500 rpm. This value should be from 2000-redline. When the throtle is chopped closed it will try to pull air from any small gap it can.
Old 11-27-2006 | 07:58 PM
flashprez's Avatar
flashprez
What type of Air Cleaner are you running?????
Old 11-27-2006 | 08:14 PM
mark2004RK's Avatar
mark2004RK
Is there a trick way to check for exhaust and intake leaks?? Also thanks for the replys!!
Old 11-27-2006 | 08:15 PM
mark2004RK's Avatar
mark2004RK
Also haven't really had a chance to check for gas mileage yet.
Anton.N
06-09-2021 10:44 AM
ib5150
04-06-2013 12:39 PM
118811fh
10-12-2008 06:08 PM
meyersmp
02-01-2007 04:22 PM
Jezcruzen
13
11-15-2006 01:28 AM
